Do not really know a lot about these tractors. I just put a clutch in, now checking over the hydraulics. The hydraulics are slow. Mostly notice with the loader, it will go up slowly and lightly shake. I changed the hydraulic filter and no change. I hooked up my flow rater, the flow rater shows around 10-12 gpm at 0 psi but hard to tell due to the indicator shaking so bad. I had around 8-10 gpm at 2000 psi. I read there is a transfer pump and screen. How to you access the transfer pump and screen to check over? Does the transfer pump send oil to the hydraulic pump? Is the hydraulic pump behind the MCV on the left side of the tractor? Thank you.
