Back again for some wisdom! So replaced my old burned out
starter that had a post connection with one that has pad for
saddle switch. Got rod and rocker all mounted and a new
switch. Last one stripped and cable contacted switch housing
starting a fire burning cable insulation right under sediment
bowl !!! The contact on cable is longer than insulating piece
on these crappy saddle switches so are you guys just
wrapping electrical tape around the contact all the way to the
tip or is there a rubber boot to cover some of the contact
surface? I?m considering modifying one of those side contact
battery boots to insulate part of the cable that attaches to
saddle switch
saddle switch
