International 404
Satohbill
I am interested in buying an International 404 Gas tractor. is there any thing special I need to look for negative or positive when checking one out.
Compared to the super A you're looking at, the PTO is center-mounted and the 3pt hitch will be factory, if it has one.
The main drivetrain is basically the same as a Super C. Engine is a C135 vs the C123, and I think a few were diesels. Biggest difference is the hydraulic system, and most of that is integrated into the differential/final drive housing top cover under the seat.
Real simple tractors. 4 speeds (unless it is an industrial, which could have a Hi-Lo range or a F-R shuttle). Transmission driven PTO (push clutch, PTO stops). Usually has 3pt with draft control.
