666 input shaft [gear drive]
PGarrett1
New User
How much clearance should there be on the pilot brg. and input shaft ? I measured bearing and shaft last night, but Don't remember what the total clearance was, but the brg. seems awfully loose on the shaft.
(quoted from post at 08:03:11 03/01/19) Either you have the wrong bearing or worn shaft. It should just slip on no slop nor tight.
It was a dumb question, as I have put in a lot of clutches over the years. Does anyone have an input shaft laying around they could measure the dia. of the shaft ? My shaft is not chewed up on the end, maybe someone has turned it down to clean it up.
if its worn or turned wouldn't the hardened surface be gone? just sayin
I doubt it should have more than .010" prolly less clearance
