notjustair
Having some hydraulic issues on the brake and steering side of my 886. I usually keep it five gallons
over full. The brakes have always had a little delay and the steering will get pretty growly when haying in
real hot weather. This winter the brake delay has gotten pretty bad during chores. I used the FWA tractor
for several weeks so it sat and when I started using it daily again I noticed this was all worse than usual.
The brake pedals will go almost to the floor with no brake and then quickly push back and brake strong.
Steering feels a little ?gritty? during that time but doesn?t go away. It never has lost prime and the clutch
and TA function as they should.
It has 3700 original hours. Good fluid and filter changed with every engine oil change. I?m thinking I need
to take off the MCV cover and go through the usuals on it. Should I just order a pump and put it in at the
same time or does it sound like it just needs the MCV done?
