So i have split my 300 Utility as it had shifting issues like not disengaging from gear with pressure on the drive line, etc.
I have removed all the gearing from the front, the planetary from the rear and have inspected most everything. So here is my question, there is a lot of wear on the finger of the TA clutch fingers, is this normal? Second on the planetary clutch the rollers seem to have grooves in the clutch body, can not tell if these were machined (intentional) or worn.
Advise ??
Thank you,
Brian[/img]
Advise ??
Thank you,
Brian[/img]
