Farmall 100 air cleaner thanks
GreenAcre
Forgot to say thanks for the salvage yard
connections, I now have one coming. I
remember when it last ran it poured oil
from the touch control block, is this
something I can just order the seal kit for
or should I disassemble and inspect first,
leaning toward the latter. Matt.
Pressure wash the box/ brake clean it, find out where the leak is. I got by replacing one control valve seal on my Super C, didn't have to remove hyd. box or fuel tank. Also the oil level gets checked with the arms back (I think, check your manual) fill it wrong and you can blow a core plug out the front.
