a new to me BN, serial 140438, with a non-BN replacement engine - runs pretty well. Tractor is on SIL place, operated by him.
Marvel Schebler carb.
Vacuum at idle is a steady 17"
Appears that the air breather cup filled with gas, so I jumped into sediment bulb, carb, etc.
Removed gas line at carb - sediment bulb shutoff stopped all flow.
Fuel level OK at 5/8" below bowl gasket. Fuel stream out of bowl drain is steady, but not heroic.
Separated bowl from carb.
Choke plate is not a full circle of brass, covers about 3/4 of inlet. There is a hinged piece attached to the
choke plate that seems to provide additional choking - under what conditions? How does it work?
The inlet drain is an open 1/8" hole, not stopped up- I expected some screen material, but it's just a straight hole in the bottom of the inlet pipe.
No tag on bowl screws, - the top surface of the bowl casting has A103 stamped on it. Does this identify carb model?
I'm guessing gas was not shut off at tank - needle valve stuck open - gas ran fast enough to overflow the inlet drain - got to the air cleaner cup.
Ideas? Questions? Suggestions?
