CenTex Farmall
Can anyone confirm that the entire run of 460s used the same size hole in the side of the rear case for the axle housing boss? In other words would any bare axle housing from any 460 fit any 460 rear case?
From studying the IH parts lists it appears that they used the same size inner axle bearing (ball or roller) for all 460s and only upped the outer bearing size for the 2 3/4 axle option. Is that correct?
