ammeter needle does not move. even when i pull the switch button,.
6 volt with generator.
googled a bit.
ahem, if i remove the battery wire from the regulator and place a light between it and ground, ammeter needle should move. (otherwise i will have to remove the battery, to check it out).
if the needle does not move, then ammeter is not working or wired wrong.
googled a bit.
