CaseIH 145 Roll-Over Plow Pros/Cons
2510Paul
I have come across a couple CaseIH 145 Roll-Over Plows with Automatic Reset. They appear to have a hydraulic pressurized canister to provide the Automatic Reset function. Can anyone give me the pros and cons of these plows? I would likely to interested in a 3 or 4 bottom.
I am going to post on the Implement and on the CaseIH forum.
Thanks.
Paul
They are a darn plow.They are a heavy plow. Signiicantly heavier than my 642.It uses a nitrogen accumulator(the little tank) to make the reset feature work. They wprk well. You can plow hard and fast,hit a rock and the bottom will just fold up and reset as if my magic.no stopping is needed.However,the end result is exactly the same as my 642(4x16)
Hi Delta. When you say "darn plow", did you mean to say darn good plow or something else.
Do you know if they were all 18" bottoms? I see some on Tractorhouse. Some say 18" and some don't say at all.
Thanks.
Paul
Darn GOOD plow.I am assumeing you could get them in 16 or 18" bottoms. But not positive. Never really thought about it.
