International 664 Ether Line
jwerner92
New User
I have an international 664 and am looking for the line that goes from the ether solenoid to the manifold. I've search online with no success and was wondering if anyone else had some suggestions on where I can locate this line. I'm assuming I may have to go to the dealer unless someone has any ideas.
Thanks in advance!
If I recall that line may be made from a 1/8 inch steel line, with similar fittings on each end like an oil pressure gauges use. A NAPA or like store should have it.
Why could it not be made from Air line that runs the slitter button on a transmission? Would flex easily and not kink if not to short length. Easy to get fittings and line.
The 1/8th plastic 'splitter' line will work-in fact some newer models use it. NAPA would/should carry it. Mark.
Agreed. There is nothing special about the line or the fittings. Oil pressure gauge line should be the right stuff.
Odds are you won't be able to get the line from the dealer anyway. It's one of those parts that rarely needs replacement, on a 45-year-old tractor.
