460 pto vs 560 pto bolt pattern
IN560
Hey guys is the 460 and 560 pto bolt pattern the same? Talking about the bolts that secure it to the rearend housing. Thanks
I'd imagine they would be the same. If both tractors are close,I'd take my tape measure and find out.
Even if the same pattern, there may be internal differences and shaft differences! Check parts compatibility, one is an H based rear end, the other an M based. Jim
Bolt pattern is same as units are identical, provided they are the same style. Early models were planetary and later ones were over center clutch. Cannot interchange the two as gear ratio that drives the rear unit is different. Well, you can, but depending on which way you went from planetary or clutch, the shaft speed will be either too fast or too slow.
Also, a 460 uses an adaptor housing between unit and rear frame due to different length of the final drive housings of the two tractors.
