So the other day I was using the 584 to load hay bales. I did 10 bales then went to do 2 more and all at once it just idled down then shut down. It would start back up but die. Tried to bleed the fuel filters and go no fuel. Checked tank and it was about half full. So figured filters where clogged to went to town got new filters plus 10 gal of diesel. Changed filters and this is the 2nd time since I have the is I changed them. Went to bleed filters and still no fuel. So I took a pumper oil can and filled it with diesel and fill the bleeders with fuel. Tried to start it and while it did not start easy it did start. Not sure what the heck happened but at least it did start and has run well since
