I have been restoring 1940 Farmall Model A. I have rebuilt the carb and had magneto rebuilt. I am now trying to fire it up. The other day I was cranking it and it backfired through the exhaust manifold blowing the cap off of the muffler. I am not sure if it is a timing issue or carb issue. I have found the compression stroke on number 1 cylinder. And cranked engine by hand so that pistion was atthe top. However i dont have a DC1-4 mark on flywheel as the manual states. I have a arrow on the flywheel. ON the flywheel cover towards the rear of the engine there is a metal pointer.
When piston is at the top of the stroke the mark on the flywheel is about 1 inch or more away from the pointer on cover. The manual states to find top dead center that the marker must be in the register. So to know if i am at TDC should the mark on flywheel be before the marker on cover or at 6'oclock. As i see if i move it to 6'Oclock it is already on the down stroke of the piston.
Any suggestion will help thanks
