Parts wanted for a Farmall Regular
mathgirl
New User
We are searching for parts or a parts tractor for a Farmall Regular. We are particularly interested in a set of steel wheels for one. Any one have any or suggestions on where I should look?
They show up now and then, join one of the Farmall facebook threads pre-1939 and
you can usually find what you need. Put a want ad on this site also. Where you
are located may make a difference, here in Kansas we can pick up wheels pretty
regularly. (pardon the pun)
(quoted from post at 11:55:07 02/22/19) They show up now and then, join one of the Farmall facebook threads pre-1939 and
Thanks so much! I'll check it out.
If you find your wheels and end up
needing an engine block like you stated
in one of your replies to the thread down
below, I've got a block, and pretty much
everything else of of Regular engine
except for the camshaft and manifold. But
I'm located in MI if that makes a
difference.
Ross
I have a set I want to take off of a duckbill F-20. I'm not sure when I'll get this done , but later this year(I hope) So if your not in a big hurry and I'm in Ohio
I have a complete regular on steel if
interested and possibly a set of steel
rears in nebraska if interested.
I'm parting out my farmall A.. .engine ran for 10 minutes and it hydro locked from bad sleeve o rings I dont have >time to rebuild it in time for bushhogging .trans was smooth PTO was
working fine axle seals need replacing .brand new ,magneto if any of this helps or if anyone needs parts let me know
Some wheels can be found if you willing to look and be patient. I do know F-20 wheels are interchangeable,
although I believe they are somewhat different in appearance. Spokes and what not. Not sure how touchy you are
about staying all original.
I have an old regular and an F-20; you could have both for $200 and throw in a pair of wheels, rims added to spokes. Just east of Pleasant Hill, MO. You'd probably have to load yourself. gm
(quoted from post at 18:36:55 02/22/19) I have a set I want to take off of a duckbill F-20. I'm not sure when I'll get this done , but later this year(I hope) So if your not in a big hurry and I'm in Ohio
We are not in a big hurry. We are located in NC and would have to plan a trip up that way when you get to taking them off. We are definitely interested.
