Help identify a tractor
DM0180#
New User
And....go. Thinking farmall regular but I have no way to tell
That's definitely a Regular. It has the open steering gear and the weird exhaust manifold with the muffler beneath the carburetor.
How hard are parts to get for those? Have an opportunity to pick this one up. I know it needs a new gas tank, rebuild of the motor and a carb, also new rubber all the way around and one of the front rims is bent . Thanks
Every part can be found. Remember it is a modestly common tractor. Not much "rare" about it. as such it would be good if you like it and want to play and spend. Worthless to flip for profit. Jim
Sorry to say but tires will cost more than the tractor is worth And no starter most dont want So you better get it free.
Many of the parts are the same as a F-20. Get some cheap tires or use F-20 wheels and tires.
I've got a bunch of engine parts for a Regular. If that one is something you decide you want to get going and need some engine parts let me know.
Ross
"Cheap tires" is an oxymoron. New tires are off the charts expensive, and it's not like you can just snap your fingers and a good set of reasonably-priced used tires will appear. Most think their bald, cracked, dry rotted husks are worth 50% of a new tire.
If money is an issue on restoration, you can find steel wheels readily available.
Wayyy cheaper than rubber.
(quoted from post at 20:21:46 02/20/19) I've got a bunch of engine parts for a Regular. If that one is something you decide you want to get going and need some engine parts let me know.
Ross
I'm new here and I'm not sure how to send you a message other than to reply to this thread. We are looking for regular parts.
I made a separate post, but right now we are mainly looking for steel wheels and a parts tractor. Unfortunately, the block is cracked. So we will need one of those eventually too.
If this is a family tractor with sentimental value then i say do what you want with it and enjoy it regardless of what it costs to get it where you want.
if this is just a tractor you wanna play around with i suggest looking for one that already running and driving because you will be ALOT farther ahead monitarily. these things are worthm aybe 1500 tops running and a set ofr front steel is gonna set you back about 400 alone. not hard to get upside down on one of these real quick
