Company Logo Shop Now
TractorLinks.com
Help Identify Hydraulic Pump from a 140.
RTR
02-21-2019 06:25:49
Not sure if this is a Cessna or a Wooster hydraulic pump. I have narrowed it down to those 2 types as they both are not as common as the other 2 types that were used (Thompson and Pesco). Please help me indemnify this pump as I would like to buy a rebuild kit for it and several spare kits for my other 140 tractors with this pump.
warren woodrow
02-21-2019 14:01:55
 Re: Help Identify Hydraulic Pump from a 140. in reply to RTR, 02-21-2019 06:25:49
The others are 3 part as far as I know . Steiner does not show your part number but you might try callinh them as they are helpful . Your pump looks very similar to the Thompson on my 424 .
warren woodrow
02-21-2019 13:42:48
Try external link - they very well may have it
warren woodrow
02-21-2019 13:33:36
external link may have the kit .
warren woodrow
02-21-2019 13:16:18
external link should have the kit .
warren woodrow
02-21-2019 13:15:29
RTR
02-21-2019 12:47:01
Yes, I can get the shaft oil seal for $4. This particular pump is 3 pieces instead of 2 pieces like the other brands. I’m worried about trying to match up the other parts to universal sizes rather than having to buy the kit at the dealer. Any ideas, ? Is there a an accurate way to measure those parts if I bought 1 kit?
warren woodrow
02-21-2019 12:20:32
external link Co should have kit
warren woodrow
02-21-2019 12:19:42
external link Company should have kit .
warren woodrow
02-21-2019 11:39:19
Use number - 383014R91 This is the IH number . The interesting thing is that the Pesco, Thompson , and probably your pump are built VERY similar and probably have some parts which interchange . I know through my experience that Thompson company disappeared and there is no trace of it on the internet that I can find . There is another Thompson Co but unrelated I believe . You most likely can get the seal, O- rings , and pump to block gasket . To my knowledge the gears, bushings, etc. are no longer available .
warren woodrow
02-21-2019 11:32:36
Check external link - they have kits for most of those old IH pumps . I paid around $60.00 for mine . Good luck .
RTR
02-21-2019 07:36:03
Ok does anyone know if there is a rebuild kit available for it other than paying $100 at CNH dealer? I have found the shaft seal for $4.00 (SKF 7443), but need the other o-rings, gaskets, etc. I don’t mind paying that price to rebuild one pump, but I want enough parts to have on hand to rebuild 10 pumps and since you can buy those kind of parts cheaper I figured someone on here knew the sizes or a source. I can always get the specific gaskets from Case IH and get the rest from a universal supplier.
Any suggestions?
RTR
02-21-2019 06:29:16
I apologize for any confusion, but the last picture showing the numbers on he pump is incorrect. That is a picture of another pump I found on the internet. The numbers of my pump are shown in the first picture.
My pump numbers are : P24EZ5G2R01 And 383014R91
rusticredacres
02-21-2019 07:27:27
 Re: Help Identify Hydraulic Pump from a 140. in reply to RTR, 02-21-2019 06:29:16
Wooster pump
