Hello all! I posted back last winter about a b414 I picked up.
Didn?t have 3rd or 4th gear or high range. Well, I got a donor
tractor from a junkyard with a good gearbox. I swapped out all
the transmission gears, resealed entire trans, diff, and front
bellhousing. Also put a new clutch and friction disc in.
Well.... I ran it for awhile, clutch worked, just don?t try to push
the pedal to stop. Clutch wouldn?t disengage, so I parked it
against a tree and put it in gear and just left it run(someone on
here suggested that). Made no difference. So I use to to cut
my field, in 3 low it started skipping out of gear, till finally one
time it stopped moving uphill and just started grinding and it
almost rolled on top of me when it drifted backwards and the
brakes locked up. Also, you cannot get it to go into high gear
unless you shut tractor off and put it in then restart, I think that
has to do with the clutch not working as well.
Well after sitting all winter staring back at me, I decided to give
it a 3rd try.... going to pull it apart again when it warms up.
Needs a head gasket, and a good degreasing again.
ANY SUGGESTIONS on the gearbox slipping issue, clutch
not working and the high/low issues? I just want to get this
thing up and running so I can actually use it, not let it sit in my
yard and be a big red lawn decoration
Thanks everyone! You?re always appreciated for the
knowledge and advice that you give
