Will a 424 2-speed Transmission fit in a Super C ?
RTR
Just curious if the common high/low transmission as found in an IH 424, 414, 354, etc. fit in a Farmall Super C or 200 tractor? Would be nice to have that feature in a row crop and have the 3 point.
Nope. Unfortunately the three Utility tractors you mentioned are all built in Doncaster, England and are of a completely different design from the Super C.
I believe some 404/2404 Industrials had 2-range gearboxes as an option. Those should work on a Super C because the 404 is a descendant of the Super C.
(quoted from post at 01:51:28 02/20/19) Nope. Unfortunately the three Utility tractors you mentioned are all built in Doncaster, England and are of a completely different design from the Super C.
Ok. Yeah someone mentioned a 404, but I've never had one of those so I didn't know if it was the same type 2-speed tranny. Guess it is a different animal. THANK YOU!
