Plowing snow other day with 240 utility. Running wide open throttle. All of a sudden the tractor rpms dropped to idle. Original thought was the throttle
slipped to idle. No such luck. Second thought was the linkage came off the carerator. Doesn?t appear to be the case. Revs up if I manually move the
linkage in front of the carberator. I have never worked inside the govenor but do have a manual. Could I have a broken spring inside the govenor. Any
ideas for me to look at? I appreciate your help.
