About a month ago and I posted a problem of shearing the key on a 1206 camshaft upon startup if a overhaul causing the push rods to be bent on half the valves.i believe I figured out what happened. While over hauling I replaced the thrust plate on the camshaft I got one from a&I when it came it was to thick so I took it to work and had a toolmaker surface grind it down to the. Same thickness as the old one. Now this is where I don't understand what caused it to Gould up between the gear and the cam but I'm realtively sure what happened would explain why it almost started then it ran dry and the friction caused it to shear. Just looking for other thoughts if this is possible
