Trent Couch
Finally after all my hard work I took the tractor out for a drive today it did well in all gears with very little howl at all. I rebuilt the transmission with all new bearings and put super m gears in 1st thru 5th and reverse idler gear this was actually a full matched set no mix matched parts and like I side it is smooth going forward easing off the clutch but in reverse it wants to jerk if I try to ease off the clutch slowly if I let it out faster it is some what smooth and still little howl when it?s in reverse with the clutch out. I was thinking the brake bands were maybe binding I jacked the tractor up with wheels off the ground (without it running) and in reverse and it seems just as hard to turn in reverse as it does forward. Also the backlash feels almost identical just by tugging the tire out and back. It?s got a resurfaced flywheel and new clutch and pressure plate maybe it just needs to be broken in? Just curious if anyone has experienced this before
