I have a 1952 M with belly pump. Last winter I dropped the pump and changed out the main seal by the drive dog. It still leaked a little. When I had
the M hooked up to a Haybuster 77C no-till drill I could only raise the drill for about a half hour of operating time, After the oil got warm it would
not lift it high enough. I am looking into using a pto hydraulic pump with separate tank and control valve this year. Do you think that is my best
option or should I look into a live pump or try to re investigate the belly pump? I think i might need 1500 psi to raise the drill. I can't go to a
bigger cylinder because its the county's drill. Thanks
