Ellis Kinney
OK, I have the brakes off the SMTA and am waiting on parts. I made a run yesterday to get the seals and the O rings. What should I be doing while I am
waiting? The bearings look good and the seals weren't leaking but they were worn. Should I run a wire brush in the holes for the balls using the drill press?
Is there any kind of dry lube that you would recommend for the balls? Should I lightly sand the brake plates? Any instructions will be appreciated. Thanks,
Ellis
Ellis
