Company Logo Shop Now
TractorLinks.com
SMTA Brakes
Ellis Kinney
02-12-2019 07:34:00
OK, I have the brakes off the SMTA and am waiting on parts. I made a run yesterday to get the seals and the O rings. What should I be doing while I am waiting? The bearings look good and the seals weren't leaking but they were worn. Should I run a wire brush in the holes for the balls using the drill press? Is there any kind of dry lube that you would recommend for the balls? Should I lightly sand the brake plates? Any instructions will be appreciated. Thanks, Ellis
Dave H (MI)
02-13-2019 14:32:10
 Re: SMTA Brakes in reply to Ellis Kinney, 02-12-2019 07:34:00
Brakes? Some people are never satisfied unless all the optional equipment is working! :)
The tractor vet
02-12-2019 09:59:21
what i use to polish up the RAMPS is a ball shaped flapper . as for LUBE you can use graphite dust like used in plateless planters. .
Janicholson
02-12-2019 09:02:07
When the parts come the stack of all internal parts placed inside the housing (on the bench) should be measured as follows: Use a straight edge across the housing and measure down to the surface of the inner disc. The total should be between 1/16th (.0625) and .040". this range allows the needed running clearance, and puts the balls down in the lower portion of their groove. that allows the pull links to be at a good angel to rotate the expander with a good mechanical advantage. The spacing is adjusted by milling/grinding (machine shop, not a 4" hand held) the housing flange to tighten the distance to the above spec. Do wire brush and polish the grooves and balls. Balls must be very round!! Dry moly spray (very small amounts) is OK on the splines and balls/grooves. No excess allowed> Jim
Ellis Kinney
02-12-2019 09:34:19
 Re: SMTA Brakes in reply to Janicholson, 02-12-2019 09:02:07
I ordered all new balls, they were cheap. The old ones were worn and eroded. I think that is what was making the brakes grab. The grooves for the balls had some dry silver stuff in them. I'm wondering if it was something like anti-seize. Thanks, Jim
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
