I have an oil leak on the Behlen power steering unit on my Farmall 450. It works fine and I do not hear any noises. I have not removed the sheet metal to take a closer look at it, but I believe I need to replace the o-rings and lip seal on the steering shaft.
I see many warnings that alignment is critical when the unit is split. I wondered if the seal/o-ring replacement could be done without disassembling the unit?
