Reassembling the 560
W.Brehm
Process of assembling the 560 after paint.
[/img]
(quoted from post at 01:24:30 02/10/19) what type of paint did you use, it looks awsome
Used Valspar IH Red on the cast. Used automotive paint on the sheet metal and clear coat.
I see the TA lever , that's in high Torque, but that's a M @ W clutch lever i also see there , that's back so that's disengauged ??
Fast, this is not my tractor but I?m not sure where you see a M&W clutch lever. In the first photo, disregarding the levers coming off the dash or steering support I see three levers. On the far side the handle with the palm grip to lift the low side release is the TA handle. Next is the gear shift with the black knob. The lever to the left in the foreground of the photo is the independent PTO lever with the top thumb push button release the lock move it to the desired position. Any other lever you see is a mystery.
