INTERNATIONAL 300 UTILITY
newhaven
Can anyone tell me the original tire size for International 300 Utility. It has 14.9x24 on the rear not sure if they are the right size
Thanks
Google is your friend!
Ag rear: 10.00x28
12.00x28
http://www.tractordata.com/farm-tractors/000/3/1/318-international-harvester-300-dimensions.html
I would think what is most important is the OD, regardless of rim size.
TractorData says 12.00x28 tire was standard. The 14.9x24 was a 13x24 when the 300U was built, needed
smaller stamped steel wheel centers and rims that were probably an available option.
We had a new 300U in 1957 and rear tires were 12x28 today's tire size would be 13.6x28. Tractordata indicates 10x28.
I believe there were industrial models that had tires like yours, old tire size would have been 13x24.
Or the rims could have rusted out and someone bought a set of tires and rims from a old combine.
JimB
One piece 12 inch wide X 24 rim was offered from IH for using a 12, 13 or 14 X 24 tire and a 16 X 24 rim also for the 14 X 24 tire.
