Worksaver 3pt
Midway
Got a Super C with an unattached 3pt with it. Wondering how it bolts to the drawbar assembly. Is there just one bolt on each side that holds it to the drawbar? A picture would be great. No fast hitch. Is it worth putting on? Would be used just a little for 3pt tools because I have a MF 135 I use. Thanks for any thoughts and advice.
There are several bolt holes on each side of the rear end. The hitch most likely bolts to those. Set the hitch right behind the tractor and look closely. You can figure it out pretty easy.
Here?s photo of C I once owned.
