Bspauld
A friend is putting a new clutch in a Farmall H and somehow they moved the adjustment on the clutch fingers, They said the manual they have doesnt give the dimension for them, does
anyone on her have that dimension? Thanks in advance.
If they had the Fly Wheel ground and it was done incorrectly the fingers could show differences. Or if something got pinched between the driven disk and the pressure plate or fly wheel. In most cases the finger adjustment was done when the PP was built. Make them all the same, and adjust the pedal free play to an inch and a quarter. Make sure there is a gap at the Throwout bearing so it doesn't turn when running. It will work. Jim
Thank you, I will go check it out, the flywheel and pressure plate was in good shape, so didnt get turned.
