300 leaking
bass
the hydraulic pump is leaking on my 300. got a kit coming . how hard of a job will it be to put new seals/o rings in the pump? anything special to look out for?
thanks
bass
Easy enough to change the seal. Problem could be a grove worn in the shaft which means the new seal won't fix it. If it is grooved you may be able to fix it with a sleeve they make for such problems.
