Nelarry
New User
Just wondering what you guys think a super MDV would be worth? The motor is loose. Thanks for any input.
All depends on condition, if i recall correctly they only built 89 smdv tractors. A stage 2 (battery under seat and possibly factory live hydraulics) would be worth a few bucks more then a stage 1 (battery under tank and belly pump). Non running does drop the value considerably, in average to good condition with decent sheet metal, tires and complete with proper parts and non welded drops and front axle i think you are in the 8-10 range possibly more. Running i would easily think 12-15k range potentially alot higher. REMEMBER the market on the older tractors has died off considerably over the past 5 years, for example 10 years ago a nice restored super mta diesel would easily bring 20-25k now they struggle to bring 10k.
Thanks for the reply. I realize the market went down on the collector tractors. I had this tractor advertised here for awhile for 7500 and never had any response really. Appreciate your knowledge
With the gas start diesels people are becoming very leery to purchase when not running. Due to the issue of cracking heads but more so due to the cost of engine parts. Its very easy to wrap up well over 6 grand in a engine overhaul.
I remember seeing the pic in the ads. Looked like it needed a lot of work and probably another Super MD to fix it up. In that condition, 4k to 5k tops. You can stick a ton of $$ in the engine if you can find the parts. I collect too and tractor prices have dropped quite a bit in the last 10 years.
