Super M drawbar
dgoodman2
Guys is there anywhere to get a decent wishbone drawbar and the belly bar for a decent price fir a super m. I want to add it to my 3pt. I've been looking fir over a year and just those two items in good condition are $500.
Wow, they have really gone up,i bought the last one from O.E.M. parts out of Chenoa, Ill. The 1 in thick drawbar was a $100.00 Are you aware the M was a3/4 x 3 and the super M,400,450 and 560 was a 7/8 x 3 for the fixed part of the drawbar! Good Luck !
Info, the U shaped drawbar started thicker at SM serial 3900 and SMD 3937. Also the swinging drawbar anchor was started with a wider space for swinging drawbar at that time. Thicker swinging drawbar was used serial 5493 SM and 5300 SMD.
Sheesh you can get a whole running M with all the parts you need for $800... Plus they made hundreds of thousands of them... You'd think you'd be able to find a junker locally that you can get the parts off of.
Unfortunately OEM went under several years ago shortly after its owner passed away. The family tried to keep it going but ultimately ended up closing up shop.
