Changed the hydraulic filter and oil on Saturday and now cannot get the hydraulics to work. Steering works but really squeals when turning the wheel. The 3 point and loader will go up but very very slowly and moves maybe an inch at a time with a lull when raising. Prior to changing the fluid it worked well and smoothly. Now appears to be full of air. All my other tractors you bleed the air out of hydraulics by turning steering all the way left and holding for a moment and then cycling to right and do same. I am new to this tractor and first time I changed hydraulic fluid on this tractor. Is there something I am missing or a trick to purging the air on these tractor hydraulics? Thanks for any suggestions or help.
