I'm trying to remember the benefits of an M&W clutch. If I recall correctly you use the hand clutch and you essentially have independent PTO and hydraulics, if you use the foot clutch the PTO and hydraulics stop when the clutch is pushed in.
I've seen a old H for sale with the M&W clutch but the handle has been removed - is there a common reason for this? If the M&W clutch is worn out does the tractor not move?
