quick hitch
bobinia
57 350 row crop with a heavy duty quick hitch ball sockets and place extra cylinder up front.anyone know about it.
Not sure what you want to know about it. Sounds like the F-300 time period hitch. It works on a F-350 also but the 350 original rear light location on left side of battery box needs moved to install. Uses 2 control valves to operate if complete to operate both ends. If the rear cylinder attaches to a duckbill arm attached to the transmission top cover it's the first style fast hitch released during F-33 production. Not a bad hitch if complete and not worn out.
Thanks for the reply,did not if it was rare or not,hitch is very good,Tractor has never done much,Thanks Bob.
The front cylinder adjusts the pitch of the implement allowing 'for instance' a tandem disk to be leveled out so it doesn't make ridges, or a plow to be angled in more steeply to suck harder. With practice they work well. Jim
