Hello all, I'm working on bringing a Farmall A back to life. I got the tractor running however it makes an awful really loud knocking/rattling/jackhammer noise when the clutch pedal is pressed. I can press the clutch quickly to get it in gear and once in gear with the clutch pedal released it drives fine. The noise only occurs when the clutch pedal is pressed and will stop only when the pedal is released.
I think the sound is coming from the coupler just in front of the transmission and it appears to have some free play in it.
What are your thoughts/advice before I split the tractor?
