Frankenford1
New User
I'm looking to buy the crankshaft pulley for my power steering project on my H. I've found lot's of listings for this pulley BUT none of them say it WILL work on an H. Many including right here in this site lists them for M, Super M, MTA, 400, and so on. Found a couple of sites show 2 different part numbers same description and fit for both and 2 prices but appear to be identical other than price. Best price is right here on YT website but does this fit my H and allow a proper installation? I've found 3 part numbers all for what appear to be listed for the same exact applications I mentioned here. The part numbers are Eaton or Char-Lynn 5515, IHS1420, and UT20094. Please clarify this. Also for clarity are the mounting brackets all show for mounting on an M, Super M ETC.. but not for an H. My pump is the Eaton pump shows bracket for M Eaton 20969, The torque generator mounting plate Eaton 121. Says for M. Is the H same part? Also can I run universal hydraulic oil in my Eaton pump as I have a reservoir for my live hydraulics with approx. 7 gallon reserve already or is ATF needed as I also have the reservoir for the Eaton pump if that's what needs to be used. Sure appreciate some help in clarifying all of this. Maybe things will go smoother if I ask ahead. Then we can GIT UR DUN! And maybe right too!!!
