I purchased a 574 a year or so ago.
I discovered that none of the lights,or gauges (other than tac) work.
Also the keyswitch was routed around with a remote starter. If the keyswitch was bad/incorrectly would that cause the lighting
issues? Also appears to have an alternator instead of generator or a different brand alternator, as there are 2 wires unhooked from
it. Could this cause issues with power lights/gauges?
I am setting out to fix the wiring and get everything going, but the stuff behind the instrument panel is a mess.
Also, had a low battery and tried to start it, didn't start. I went through and changed terminal ends and the battery. I went to
start it recently and it basically keeps cranking now, regardless of if I am hitting the remote start or not, if the battery is
hooked up. I've tried hitting the solenoid, but no dice. I assume I welded the contacts trying to start it with lower power. Sound
plausible?
Thanks
plausible?
Thanks
