806 oil pressure gauge
KFFarm
I’m going to put a oil pressure gauge on an 806 with the 301 gas engine. If a 301 engine were in as good of shape as it could possibly be in, what is the maximum oil pressure it will create? Will the 45 psi gauge be sufficient, or should I go with the 75 psi gauge?
Don't those have an oil pressure regulator like the diesel models do? If so it would hold it to about 50 down to about 30. I think the diesel was from 38-55 PSI oil pressure by the regulator.
Gauges of all kinds are supposed to run at 2/3
of the average pressure they will encounter.
Pressure when oil is cold will require the
75 lb. gauge.
Jim
