hey am new here have looked but not finding what i need to know so if would help m thanks,
my super m is dumping oil out the vent tube only when going up hill runs good any ideas
Sounds like the drains on the head are plugged. Pull tappet cover and clean. Then drop oil flush with a bit of fuel oil carefully spray/poured down the drain to check they are open. The fuel will run out the pan drain. Using a separate catch pail you could run it through a few times to help with opening the drains up.
(quoted from post at 17:52:24 01/24/19) Sounds like the drains on the head are plugged. Pull tappet cover and clean. Then drop oil flush with a bit of fuel oil carefully spray/poured down the drain to check they are open. The fuel will run out the pan drain. Using a separate catch pail you could run it through a few times to help with opening the drains up.
thanks i was thinking on that line but was not sure
