Rebuilding a B and I didn't see but one mark on my camshaft gear. So, I matched that with the crankshaft gear. Then when I put in the governor gear I figured that the one mark on the camshaft gear should be matched to the gear on the governor. So, I turned the crank 180 degrees and matched the marks on the camshaft and governor gears. I put the cam cover and governor cover back on as well as getting the pulley on the crankshaft. In comes my brother and says "you've got it all wrong"--that the camshaft gear has two marks on it and turn the crankshaft 180 like I did will not put the engine in sync. So, before I go to the trouble of taking all this apart again, is my brother correct? I swear I did not see two marks on the camshaft gear.
