Company Logo Shop Now
656 hydrostatic
Brad
03-30-2001 09:04:13
Our hydro is acting up in our 656. The drive pressure starts jumping at around 4000 psi. It will pull itself forward and reverse in low range but has no draw bar pulling ability past that point. In high range It just vibrates the wheels and sounds terrible. THis occurs in both forward and reverse at any RPM. We have changed oil, servo valve, and foot&inch valve.
Any insight to our problem would be greatly appreciated.
thank you,
Brad
Ace Schrunk
03-30-2001 10:11:16
 Re: 656 hydrostatic in reply to Brad, 03-30-2001 09:04:13
You almost need to flow rate a hydro to determen problems could be just the charge pump
Alvin
03-31-2001 11:33:01
 Re: Re: 656 hydrostatic in reply to Ace Schrunk, 03-30-2001 10:11:16
If you have to rebuild the hydro, better sit down==about 5 g"s
brad
03-31-2001 15:09:29
 Re: Re: Re: 656 hydrostatic in reply to Alvin, 03-31-2001 11:33:01
we had the hydro apart but everything looked real good in there. We found a bad seat on the servo valve and thats about it.
Today's Featured Article - ... [Read Article]
Latest Ad: Front hydraulic pump for loader .. drives off tractor front. Mount bracket included. Greisen brand which is my favorite brand for hydraulic controls. This is use some, then removed and stored inside for several years. Can ship send along your zip for rate. thanks [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
