DTK
My 504 row crop gas won't raise my Hutch. 61' 10" auger, otherwise the hyd. Works well. The pwr. Strg. Works good,it lifts reg. Implements fine. It has a whine in it at lower rpm. New filter and clean oil. Any help would be appreciated. Thanks DTK.
Without knowing at least pressure, and preferably flow, anything is a guess.
However, that is a large and heavy auger, probably designed to be lifted with a modern 2500+PSI hydraulic system.
Sure it will not raise that auger because of the pressure and flow it takes much more that a 504 would have and that auger is almost too much for the 504 to run.
