super a hydraulic pump
khouse6
removed and in the process of replacing hydraulic pump. new seals. the shaft does not go through the new o-ring. not very strong, must not be strong enough to push it through. hmmm
thinking about taking a Dremel and grinding, slightly the front edge of the shaft shoulder, where it would help stretch the o-ring.
any hints. yes, add grease. did that.
Some times dropping them in hot water helps since doing that causes them to expand a bit
brought the pump into the house and let it warm good. put a bit of oil onto the shaft and it popped right in.
