Carb difference
Little different idle circuit and other metering for gasoline models, 23/32 venture in the SH and 25/32 in the 300. Two gasoline carburetors used in a 300 were different 361525R1 and R2. Rare to find a R1 now. Tried to spell venture different but spell checker kept changing it.
All I was referring to was the choke shaft is the same and can be used with a cable or rod. SH and 300 carburetors are the same size outside but bottom and top castings are different on the gasoline type.
