Trent Couch
I finished rebuilding the Governor with new bearings and bushings and rebuilt my carb I was attempting to adjust the Governor to get the carb to Governor connection right from the book and the pin that slides in where the vent tube is on top of the Governor slides In freely at wide open throttle and low throttle. I got the bottom bowl of the carb off looking at the throttle plate opening and closing and I noticed that the throttle plate is almost closed at low throttle and at wide open is completely open however it changes from close to wide open around 1/4-1/2 throttle. To me it seems that the throttle plate inside the carb should open slowly as I open the throttle more and more instead of all at once between 1/4 to 1/2 throttle. I re-read the book over and over maybe I?m missing something is this normal?
