D361 in 806
Bad rings, hole in piston, Worn rings on all cylinders. All possibilities you will have to check things since we are not able to see what is happening.
If it is actually coming up and not out from the tappets by the rocker arms where the oil comes out to lubricate the rockerarms and tube.
Can't say for sure like Cat guy said we are not there and don't know the tractor . How bad is the blow by on the crankcase breather , if she has a bad case of asthma then the little dealing has internal injury's and it is going to get expensive .
