C200 Engine
GSR
Anybody have a C200 (like 544) engine? Doesn't need to be running, just complete and rebuildable. Thanks
I've got a good C200 that was removed from a 544 hydro that the hydro was bad in. It ran good with no smoke . Has been stored inside has most accessories still on it. Won't be able to get to it until spring because I have a compression fracture of the knee I've been dealing with. You can call me two zero seven 827 five 5 nine 1. leave a msg if I don't answer as we get so many junk calls we don't answer the phone if we don't recognize the caller.
Just a heads up, if you are looking for an engine for a 544, and find a C200 from a 574/674, the rear engine plate will be different. If you have the rear plate no big deal, but if you don't and you buy an engine from the opposite series you will need one. Sounds like you both have 544's though if the deal works out.
Definitely not an H, that is a later model engine obviously. It does not interchange with many models. No expert on them to tell you which ones. Maybe someone else will chime in.
544, 574, 674, and then there was some of the industrial models but I can't remember the numbers for sure, 2400 or 2500, maybe 3500???
